Lower unit problem
cledustheman
i like to know if a 90hp evenrude lower unit will work on a 135hp or do i need to get another 135hp lower unit for it :confused:
cledustheman
Re: Lower unit problem
Originally posted by cledus:<br /> i like to know if a 1977 90hp evenrude lower unit will work on a 135hp or do i need to get another 1977 135hp lower unit for it :confused:
cledustheman
should the gears be the same or they diffrent and will the 90hp lower unit handle the 135hp moter if everything should bolt up or would u have problems in the long run if it works
jimmbo
just for your info, There is no such thing as a 1977 135 hp. 1976 was the last year, for 1977 they made a 140
cledustheman
that s right it is a 76 rude 135 and 90hp will the gears be the same or they diffrent and will the 90hp lower unit handle the 135hp moter if everything should bolt up or would I have problems in the long run if it works
