Hello all,<br /><br />I have a 1993 Bayliner 1800 with a Force 120 outboard engine. I just took it out for the first time today in the ocean. Not more that 10 minutes out and the the motor comes to a screaching half and will not turn over again. The motor seized. After getting it back to my house I pulled the drain plug in the lower unit and no oil came out. It was empty! I also noticed that the seal around the drain screw was broken. Apparently the oil had been leaking out on my grass and I didnt see it. I now noticed a patch of dead grass in the yard, go figure. I put the motor in gear and I can barley turn the prop. If I put oil in it, is it possible that i can unfreeze it? Or is my lower unit totally gone? I also noticed that the motor will not turn over even if it's in neutral. I pulled the lower unit off and the engine starts fine. Does anyone have a used one for sale?<br /><br />Any advice would be great... <br /><br />Thanks,<br /><br />Joey
