My recently acquired 1958 merc keikhaefer 58A seems to have problems with water entering into the lower unit oil, as it is milky after I water tested it. So I took the lower unit off of my other parts motor and was looking it over to see if I wanted to just swap the two. I got to looking, and when I poke a screwdriver into the top oil hole I can see the screwdriver when I look down the rubber tube where the impellor pumps water up to the engine. Am I missing something or does that tell me that this lower unit as well will let water into the oil? That isn't normal is it? I just don't want to swap the two to find out that this one leaks too?
