Hi Guys, I have been refurbishibg a 59 Evinrude 10HP that sat for about 20 years. I started it today for the first time in trash can full of water and let it idle in neutral for about 10 minutes. When I shut it down I noticed a thick coating of brown/milky oil floating on the water. I drained the lower unit and the 90 wt oil didn't look milky, could this oil be from the exhaust or do I need to replace the seals in the lower unit? If I need to replace the seals what ones would you expect to be bad?
Thanks to all you folks that take the time to help.
RV
RV
