Lower unit question
unbtabl
When I went to change the lower unit fluid, I noticed that neither of the screws (top or bottom) had o-rings or washers on them. They weren't stuck in the unit either. Is this correct?
jbuote
Unlikely that's correct..
Not a pro, but as far as I know, there should be o-ring or washers there..
What drive unit do you have?
The experts will be able to tell you for sure if you provide that...
Ayuh,.... Merc uses grey hard paper washers as gaskets,......
Yer supposed to replace after each use, though I closely inspect what's there, 'n replace when I see reason too,......
Many times they get stuck in the housin' side, 'n are the same color as the castin',....
If ya scratch it with a screrwdriver checkin' it, ya oughta replace it,....
dubs283
Stuck? Do you mean tight?
Either way, yes you need ONE gasket per plug upper and lower (two total) and plugs tightened with a suitable flat blade driver (wide blade) by hand
Can't tell you how may times Ive seen drain plug gaskets doubled and even tripled up, sure to cause leaks.
Fill drive from the bottom, up to vent hole in top with high perf or suitable grade gear lube and top off monitor if equipped
And as Bondo says, definitely check for remnants of old gaskets in shouldered portion of plug holes, I use a bent pick, works awesome...
Depending on the year the newer ones went to Yellow gaskets, part rubber
Never had one leak
But for that matter never had the paper ones leak either
Oh and they also have blue ones (also paper)
