1998 johnson 150 hp oceanrunner.<br /><br />i drained the lower unit oil and dropped the lower unit per my manual. replaced the entire water pump assembly, and then reassembled. put new oil in. on the muffs, engine ran fine, but i noticed water coming out from the seal between the upper and lower unit. is this normal? there wasn't a gasket to install, but i don't see where the water is coming from if i got the water tube installed correctly. i went ahead and launched the boat and ran it. no problems at all, ran great, no overheating- so the water pump i installed seems to be working. but still concerned about the water i see entering and exiting between the units. normal? also, the lower oil was a "little" milky. am i in trouble? again, the sea trial went great, so i'm hoping all is fine.
