Hi, I am a first time boat owner. I just got done replacing all the seals and water pump in my lower unit. (1973 Johnson 115) Looking back and doing some final reading I noticed the DO NOT intall the seals dry. Well that is what I did of course. Just wondering if it is going to be ok or is this something that has to be done and worth draining and tearing everthing back down again. Also...those 4 little bolts with the o-rings on them ....prop shaft housing? the o-rings keep on shredding on me. Do these bolts only need to be snug tight?
thanks
searay24
thanks
searay24
