I am replacing the pinion gear and the prop shaft bearings in the lower unit.
1) Is it necessary to re-shim to set gear clearance and backlash? I have heard some say that re-shimming is only required if the case is replaced.
2) Is it possible to set the clearance and backlash with out Tohatsu specific tooling?
Thanks for your help!
