Matthew A.
- Joined
- Jan 24, 2006
- 232
Gee...I wonder if the reason why I was seeing a decrease in fuel mileage as well as loss of speed could have something to do with the amount of prop shaft play I discovered. Enough play to where the shaft would rub on the inside of the anode located between the prop and the bearing carrier. My friend came up with a brilliant idea. Why not simply increase the diameter of the hole in the anode so the shaft can't rub on it anymore. I must admit...it's hard to argue against such sheer genius. After all, he did point out that filing the anode would also make for better contact with the salt water, thus increasing it's ability to protect the lower unit from damage due to electrolysis. After thanking him, I pointed out that corrosion is only an issue if there's a lower unit left to corrode.
Now that I have the lower unit completely disassembled, any ideas where to find inexpensive bearing sets for an 88' 85 hp. Also, is the bearing in the bearing carrier replaceable?
