Hello,
I'm about to remove the lower unit on my mercruiser outdrive (alpha one Gen II) to replace the impeller. I'm only removing the lower unit, not the entire outdrive. I understand you must be in forward gear to remove the entire outdrive. I have researched the forum but cannot determine if I have to be in forward gear when removing only the lower unit to change the impeller. What is the requirement in this case? Is there any benefits to being in forward gear or should it be left in neutral?
Thanks.
Thanks.
