Lower unit seal sealant additive?
ba_50
Ship Shape on TV used something called ceal-ant or something like that in the lower unit of a big motor instead of replacing seals. Has anyone used anything like it and does it work? Thanks.
Scaaty
Re: Lower unit seal sealant additive?
Super snake oil...replace seals.....
KYHunter2
Yep,
Sorta, kinda , like stop leak stuff ,you pour in cooling system/ radiator.
It may be a temporary fix , but usually just that.
And like the way , it clogs up the passages in a radiator.
It would seem to me , it would gum up everything in the gear box.
Not counting , failing to prevent leak .
Resulting in the water intrusion repeating.
Alot more costly on an outboard , rebuilding a blown lower unit, then replacing a radiator.
KYHunter
R.Johnson
A seal is a spring loaded rubber seal! Once the rubber is worn away, their is no addative that will replace that.
