Lower Unit Seals
dstuard
Will I have to completely take the lower unit apart to change the seals in my 1983 115 HP Merc? Is this a job for the shade tree boat mechanic?
Solittle
Re: Lower Unit Seals
Not a job for the shade tree mech. without a factory manual, access to tools and patience.
scubarobby
Remember to make sure you need to replace the prop shaft seal before you open that can of worms. You can test it with a bicycle pump but dont go over about 15 psi. the water pump and shifter shaft seals are usually a peice of cake. I never changed a mercury prop shaft seal thank goodness.<br />robby
dstuard
I have a manual and patience and basic tools. I guess I will get the bike pump and try and see where it is coming from.
dstuard
Will I need the special tool to remove the shift shaft bushing?
