Hi,
I am having trouble adjusting my lower unit to shift into reverse. The cable is adjusted as far as it will go and still won't hold in reverse. If I try to turn the prop it jumps out of reverse , like it wasn't all the way in. I set it in nuetral like the book showed when I put the lower unit back in place but when I took it out for the first time I had to hold down on the lever to keep it in gear. After adjusting the cable to the max It still won't stay in when I try to rotate the prop. There seems to be a lot of play in the shift shaft. I'm afraid to move it one spline on the shift shaft for fear it won't go in forward gear. What does the experts think?......................Jerry
merc 60hp ob343140
merc 60hp ob343140
