I stripped the drive gear last summer on my 1990 150HP Force, and recently bought a used lower unit to replace my ruined one.<br /><br />I mounted the lower unit the other day, and noticed that when I shift into gear, there is some play in the propshaft. I can rotate the prop about 1/8 or 1/6 of a turn back and forth. I can't find much info, but I did find one post on another forum that said this is normal, and it is the slack in the slider between forward and reverse...is this correct?<br /><br />Needless to say, after busting one lower unit last year, I'm very paranoid about this used one that I purchased. Should there be any slack in the prop shaft when put into forward or reverse?
