Re: Lower unit swap 10 hp to 18hp
Yes, that's a 1957 18 HP, and the lower unit from a 1956 10 HP (QD-17) should fit. The gear ratio is the same, but the stock prop from the 18 will be a higher pitch then the prop from the 10, so unless the 18 will be on a very heavy, non-planing boat you'll want to swap the prop for the higher pitched one. Good luck.
