Lower unit swap
89retta
Would a 1980 100hp lower unit fit on a 74 120hp?Both are Chrysler.Thanks
89retta
Re: Lower unit swap
Anyone really need to know this as i would like to buy it if it fits mine.
thompy
Re: Lower unit swap
they should, check where you water goes into the lower unit, there are 2 different lowers one has the water pick up on the torpedo and the other is above the torpedo and below the cavitation plate. im not sure if the 2 styles are interchangable
89retta
Re: Lower unit swap
No way of checking.The 80 lower unit is a 5 hour drive.That is why i'm trying to find out before driving to pick it up.Thanks
adamjr
Re: Lower unit swap
Have you thought about asking the person selling it? Just a thought.
89retta
Re: Lower unit swap
Thanks Frank.The guy just told it would fit but from what i have read on here.You are the guru of Chrysler so i'll take your word.Here is a pic of the leg.
Frank Acampora
Re: Lower unit swap
Around 78 or 79, they redesigned the lower unit. That is a one piece lower and you have a two piece lower unit. Although the drive shaft splines are the same, that is all. The gears are different, the drive shaft length is different, the prop shaft splines are different, and the bolt pattern is different. AND, unless that has been painted, it is a Force lower, not a Chrysler. All Chrysler and early Force engines were white.
Chrysler did advertise that the one piece lower was faster. a year ago, I actually did the swap on my Glastron V153 with my three cylinder 90. I swapped the block from a two piece midleg and lower unit onto a one piece midleg and lower unit. Same block, same carbs, same mounting, same weight. Only change was the mid and lower units. As Chrysler advertised back then, the one piece lower is about three MPH faster. 42 MPH vs. 39 MPH
NOW: If you want to do the swap. send me a private message. I have a number of midlegs sitting extra. Everything from your engine will swap onto the newer midleg--nothing significant was changed until the 1990s
