Re: Lower unit swap
Uhhhh...I think you will find it is a bit harder than described above. Pulling the bearing carrier is difficult without the proper tools. I am assuming you have the tool, but it can still be very stubborn, and often requires oxy/acetylene heat to break it loose. Also, without a driveshaft splined holding socket, you will not get the pinion nut torqued properly. Then there is the problem of actually holding the pinion nut (so you can torque it) without the special tool.
Shimming the driveshaft gets you started with a "stake in the ground" fixed dimension. Then the other shims are selected using various methods, dial indicators, etc., and those shims are what adjust gear backlash, propshaft end play, etc. The only place that this variance can come from considering you are re-using all your internal parts.....is the case machining tolerances. And you are swapping cases....
So,.....it will be a crap shoot....you may get it close enough.....
Don't get me wrong....I would do EXACTLY what you are doing if it were mine. You should study up a bit on gearcase shimming, and specifically, the different ways to check gear backlash....
There is a guy in Interlochen, MI, his name is Joe Eby, and he has some informative videos on Youtube regarding shimming. Problem is, he doesn't do a V6....this is a V6 right?
