challenger
- Joined
- Mar 12, 2006
- 15
Hi I have a 1995 maxum with a 4.3 liter alpha one drive. I have taken the lower unit off to replace the seawater pump. Underneathe the large round anode at the back of the unit is a bolt that goes from the bottom half and threads into the upper half holding the cas together. The bolt broke while taking apart. I have since drilled out the bolt and will retap the hole. Does anyone know what the bolts are made of?(steel,hardened steel, aluminum, zinc coated) I dont believe it was stainless or I wouldnt have snapped the bolt. And I believe stainless gets corrosive if under water for long. Also the four bolts that bolt the lower half to the upper half(two on each side), three of the nuts have hairline cracks in them. What kind of nuts can I get to replace them? Thanks Shawn
