Hi Guys, I've got a 92 model 70hp Johnson that I'm trying to change the water pump in. The problem is the lower unit won't separate from the exhaust housing. I've disconnected the shift rod and taken off the trim tab, the bolt under the trim tab and the 2 bolt in front of the trim tab and the 2 bolts on each side of the lower unit. I can a little movement but for the life of me I can't get the lower unit off. I'm thinking the drive shaft is stuck in the power head for some reason. Does anyone have any idea of how to free it up and get it out. I know this can't be the only time this has happened and I'm just hoping someone has dealt with it before and can give me some ideas. Thanks to all.
