Re: Lower unit
White is single exhaust, black is dual exhaust. Either will fit on a pre-Mercury engine.
If it is not a Mercury lower unit, Any differences do not matter. Later units had a bigger water pump which is always a plus, but the earlier water pumps were adequate to do the job. Bolt patterns, prop shaft, exhaust snout are all the same. As a matter of course, you should have replaced the water pump impeller while the lower was off the engine, that way you will have no worries
The only difference you may find is that the 85 MAY have a 2 to 1 ratio. If your 125 lower is pre 1990 or 89, it will have a 1.76 to 1 ratio. If it is post 1990 or dual exhaust, it will have around 1.85 to 1.
IF the 85 is 2 to 1, you may need to step up in prop pitch to keep engine RPM in the operating range. The positive is that you may also see an increase in top speed.
As far as mounting the lower, it is heavy so an extra set of hands will help but is not absolutely necessary. You will need to "Feel around" for the crankshaft and you may need to turn the propshaft (in gear) to align the splines.
