I took the powerhead off my Mercury 1150 (1976-1978.) When I took it off it was in nuetral. Later I noticed that the shifter pulled out. I wasn't sure at what orientation it had been in. The Seloc manual I have says do all the diagnosis of lower unit with the powerhead attached and I don't know why. Without taking it apart, I think it's the cam I style shifter without preload pin. I thought that I should be able to turn the drive shaft by hand. I can't. I can only wiggle it a little bit (and the prop moves a little along with it.) Seems like it kicked in gear. I tried putting the shifter back in and turning it to put it back in nuetral but turning it does nothing. Is something wrong?
