Lower Units and Casting (housing) numbers 65HP '71 Merc
turtle1173
Hi,
I've been searching for a replacement lower unit for my 1971 65HP Mercury. Do I need to find a lower unit with the exact casting (housing) number that I have? Does this show what is compatible or not?
My housing number is 1623-4021 but I've seen several that were close yet not right on. Recently I found one that was a 1623-4930.
Can anyone help with this?
Thanks!
Laddies
Banned
Re: Lower Units and Casting (housing) numbers 65HP '71 Merc
If it's a short shaft it's a A4 or the long is a A5
1623-5246A5 or 1623-7339A2 are short
1623-5246A7 or 1623-7339A25 are long numbers that number I cross it to.
turtle1173
Laddies, thank you for the response.
Do you happen to know what other casing numbers I can be looking at that will be compatible with my motor? Anything other than 1623-4021??
Thanks,
Shane
Laddies
Banned
Those are casting numbers the number on the casting won't have the A5 or what ever justs the first 8 digits but the long and short shaft engines use different castings back then. You could install a complete 6 cyl unit but the gear ratio is different
turtle1173
Do you know if this one will work?
Casting number is 1623-5243
It is off a 1972 115HP Merc, which is supposed to be a 2:1 gear ratio.
Thanks!
Laddies
Banned
If it's a complete unit it will work other than you will have to change the prop pitch to make it work
Ayuh,.....
Those old 650s used a Gear Ratio All they're own,......
Other lower units will bolt on, but will be geared differently....
