Re: Lowering the outdrive for the winter- Why?
I've always kept the prop and drive tightly wrapped with a tarp to protect the prop and innards, so no water gets in that way. Maybe some 2x6s under the wheels to block it up a little higher would do.
As for the pullling of the drive every year- do people really do this? I did an informal survey around the neighborhood, and no one does this. I know the book says to, but no one does it. Most have had their boats for many years, and never done this.
Please don't bite my head off, but some explainations as to the why and why nots.
thanks
- Ujoints need to be lubed seasonally
- Alignment should be checked
- Gimbal bearing should be inspected
- You can't do a thorough inspection of the bellows from the outside
None of these things are going to need annual attention as far as replacement. In other words you are not going to REPLACE your gimbal bearing or bellows every season. You will rarely need to adjust your alignment. But things decay and change over time Inspection will tell you when it's getting to be time. Trust me, once a bellows goes your short cutting a couple hours of labor annually is going to cost your about a grand when water gets in there and forces itself past the drive seals and requires an partial upper teardown.
I always get a kick out of people who say they never do something and are fine therefore it's not necessary. Seatbelts? Everyone is always fine until they are not. Same with boat boat maintenance. I know people who think it's a waste of time to run blowers.
If you are inspecting the most critical part of power transfer in your propulsion system I think it's a mistake. You'd be better off not changing spark plugs. If you eat ujoints, splines or drive seals it's gets pretty pricey.
Give me a choice between spending an hour changing plugs cap and rotor vs inspecting my drive train and it's a no brainer. Then manual doesn't print that info for no reason
M
