Lowrance Elite-7 HDS... recommendations / Suggestions?
mbhoag
I think it is time to replace the 27 year old fishfinders on my 1986 Bayliner bass boat (Eagle II in bow, Hummingbird at wheel console).
I think I will probably move the Hummingbird to the bow, with transducer on trolling motor, and have new unit at the wheel.
After researching quite a few, I like the looks of the Lowrance Elite-7 HDS with the Lowrance Lake Insight Maps.
What I like:
Large 7" color screen
GPS/Chartplotter
Lakemaps with contours
Downscan imaging
Up to 3 screens at once
3000 waypoints
100 routes
under $1000 bucks
Anyone have experience with these units, the good and the bad, or better suggestions?
Thanks for the help!
OllieC
Re: Lowrance Elite-7 HDS... recommendations / Suggestions?
I just installed the Elite 7.
I love it. The downscan is really cool. The chart plotter is very detailed. I just fished around some shoals that "eat boats" every year. Good unit.
The only thing I didn't like was drilling a 1" hole in my transom for the transducer's "blue" connector. You would think with with today's technology the connector could be smaller.
Enjoy,
Ollie
OllieC
Also, the back order on the cover stinks..... I have no other complaints.... :)
mbhoag
Drilling a hole in the transom?? I thought is was an external mount transponder... only a couple of screws would be needed..
What did I miss?
mbhoag
As for the cover, I might just have my wife make me a slip-on cover out of upholstery grade vinyl or leather. We have an industrial sewing machine as she used to do upholstery years ago.... then I can get my boats name added to it (Passin' Bass) :-D
OllieC
What did I miss?
Yes, the unit comes with an external transducer and yes you need to screw in the mount below the waterline - however, the cable and connector are attached the the transducer which you need to route to the helm (assuming that's where it's going) . If you are going to drape the cable over the transom where your outboard is and then route it through an existing hole, you should be good.
For me, I have an IO and had to drill through the transom. Otherwise I would have a cable routed over the transom and on top of seats to enter the gunwale.
Have your wife make me a cover LOL - ;)
I should have my cover in a couple weeks.
Ollie
Sledryder
The Humminbird and Lowrance will not work well at the same time , one unit will get feedback from the other.
mbhoag
Thanks for that update, I would not have known that. Maybe I will just mount the new unit on a gimbal that I can spin around to see from the bow or helm.
mike165
A bit slow to load,and you need to keep the batts well charged
