The keypad on my HDS 5 GPS keeps locking up. Has anyone had the same problem and figured a solution?
It powers up and works fine to start but then the keypad locks up. The screens are still there and functioning but the keypad does not work. You cannot even switch it off. If you unplug it, leave it for a while and plug it back in it works again.
Don't know if it has anything to do with it but it has been really hot on the lake and the GPS sits in the sun and gets hot to the touch???
Anyway - the lowrance website gives three steps to fix it:
Download latest software
Soft reset
Hard reset
I did all of those in sequence and I still have the same problem.
If those dont work Lowrance says to fill out a return authorization. I am really reluctant to send them back the GPS since this HDS 5 is actually a replacement for the 527 I originally bought and had to return because the sonar did not work. And it took them about 6 months to finally get a replacement unit to me.
I would appreciate any advice!
Soft reset
Hard reset
