Lowrance Hook 4 ..HELP
Rub-a-dub
Ariving at my fishing spot, I put my Lowrance Hook 4 on stand-by and proceeded
to front of boat. I turned around and saw my co-angler punching buttons on my LH4.
He said he was trying to see the depth. When I went back, everything was gone!
Settings, preferances and most important.... all my waypoints and trails! The LH4
was back to factory reset. My question, does anyone know if I can recover my
dozens of waypoints? ..:grumpy:
dingbat
Not that I’m aware of....backups are essential
Are you sure it was a factory reset? I’ve operated a bunch of different units. The reset function is usually buried deep in the menu pages and requires multiple acknowledgments before proceeding.
Never heard of a “stand-by” function. What is it’s purpose?
Rub-a-dub
When I use my unit on my bow I put console unit in "stand-by" which turns off transducer to keep signals from interfering with each other ..I don't know what he did but somehow every thing was deleted..
Rub-a-dub
Talked to Lowrance tech. and was told that a certain sequence of buttons pushed will
completely remove all stored data including waypoints, trails etc. and there is no way
to recover them. Co-angler must have hit that sequence. Tech told me how I can back-up
info with a SD chip as I will be doing from now on. (I was not aware this could be done
with this unit)
