Re: Lowrance iFinder H20 handheld gps
I've got the iFinder and it does everything I would expect a handheld GPS to do for me. The mmc card is also compatible with the x18c sonar/gps unit on my boat.<br /><br />The only downside I found is not really a problem with the unit but the mapcreate software. This glitch is mainly if you plan on using it for land navigation since there are some highways listed that have been closed down for over 10 years and other new highways that have opened up at least 5 yrs ago that are not listed. This only pertains to recently constucted and/or closed highways and Lowrance may have current updates in the pipeline to correct this from the three yr old 6.2 version that I am using. If you plan to use it for marine purposes, I don't see this issue would be a prevailing problem. <br /><br />All in all, I don't think you will be disappointed in the iFinder.
