Hey All,
I have a Lowrance LCX-26c HD Sonar/GPS combo unit that I installed last year.
When I installed it the GPS Antenna had no problems. I never got to use it last year because the season ended. Over the winter I installed the Fuel Flow sensor, and this year I finally got the boat on the water.
As soon as I turn the unit on, it says GPS module not responding, If I go into the NMEA devices, it always shows the Fuel Flow sensor, but does not show the GPS antenna.
If I crawl under the helm and unplug the T-Connectors, and terminators, and plug them all back in, the GPS antenna will apear in the NMEA Devices untill I turn the unit off again.
I Have it connected as follows...
{=} - LCX-26c HD
\/ - T-Connector
-+ - Terminator
[] - Fuel Flow Sensor
@ - LCG-2000 GPS Antenna
Hopefull that's easy enough to follow?
Thanks for the help/suggestions.
-TheChad
{=} - LCX-26c HD
\/ - T-Connector
-+ - Terminator
-TheChad
