Lowrance LMS 522C power cable/transducer compatible with Lowrance Hook 7...
staydry
Bass Pro had a Hook 7 reduced to $175.00...was just the base unit....no cable or mounting bracket....
The connection points for the cables looked just like mine on my LMS so I bought it...
At my boat...on the trailer....plugged in the Hook...power & transducer cable fit....unit came on only in demo...didn't have manual with me to try switch to regular navigation but it can't be that hard...
Question is I guess the power cable from the LMS is ok to use with the Hook but what about the transducer? Will the LMS work with the Hook...will "downscan" be available ... or should I just go ahead and order new cables/transducer??
Thanks
