LU gasket/seal kit/s numbers for a 1969 Chrysler 55HP
TireFryer
Prev owner removed pivot screw = dropped dogbone yoke! Hence, time to drop the LU and fix the issue.
Being NEW to outboards, I could use some assistance in gathering the correct gasket/seal kits before I rip into this. Also, I am going to go ahead and change out the impeller as well while it's apart, so gasket kit # for that too... Propeller shaft oil seal and O-ring (to be used in/with Bearing carrier)
Thank you! :)
