aarongreen123
- Joined
- Jul 23, 2010
- 133
noticed that the top lower unit screw had milky oil leaking from it on my 84 Merc 90 OB. Figured it didn't make sense to start worrying about other seals as long as there was so much oil leaking out from the vent screw for the gear oil. I took the gear oil out, white as the pure driven snow oddly enough. Attached is a pic of two new screw seals and the two old ones. Is this what happens to the old ones when they wear out? Did this guy use the wrong seals? Am i now using the wrong ones? I had the parts guy triple check but who knows....the old ones look thicker to me by a lot, and i can tell you that the new ones fit on the screws much more loosely. Old ones on the right. Nothin leaking now at least.
