LU Seal Leak?
Dave K.
While changing out the gear oil this past weekend, the old oil had a stream of lighter colored almost tan looking oil mixed in the w/ the rest.
Is this a Seal Leak & is replacing the LU Seals a difficult job?
Thx Dave
pnwboat
Re: LU Seal Leak?
It's fairly easy to do, if you have good general mechanical experience. Also depends on which motor you have. Some are easier than others. Corrosion is also a factor as these motors have been around for a while. Some parts/bolts can be difficult to remove.
Dave K.
Re: LU Seal Leak?
Model 856X4L.
Sorry about that, I just realized I didn't include the model. Thank you & YES I'm pretty good w/ a wrench. I changed out the impeller two seasons ago so most of the bolts have been out & I used antisieze to install.
I assumed I did have a leak as I've not seen this stream the past 5 years.
Thanks again. Dave
jerryjerry05
Re: LU Seal Leak?
It also depends on how much water was in the oil.My 85's both drain plugs weeped a little water.No mater what I tried to seal them with.I always found a bit of colored oil in the lower when I changed it.
You need to get it pressure tested before you disasemble.It might be just a fill gasket leaking.J
