Re: lube for hone?
Trans fluid works fine, we used it all the time when we ran out of honing oil. If you want to cut it down thinner, mix some WD-40 with it.
Slower is better, so you keep control. It depends on when type of hone your using. But slower is better, under 300rpms. Make sure you keep the hone moving in and out, and not in one place long.
