lube oil vent
Tony Downey
Hi everyone,
So I went to add new lube oil to my SX cobra leg today, filling from the bottom and waiting for the lube oil to start coming out of the vent. Sadly it didn"t happen and i think the vent is blocked and air is trapped inside. How do i un block the air vent on the leg?
Many thanks.
Tony
jerryjerry05
I think your supposed to fill from a plug under the cover on the back.
The square shifter has a screw off to the side it is the oil fill.
The thing on top is the dip stick.
bruceb58
On the Cobra SX(same as Volvo SX), you fill from the bottom. The vent is behind the cover.
