Hey Ya'll,
Just got a 1977 Johnson 70 (70EL77S) Got a digital user manual on order but trying to get some things done on it now. It has been sitting for a while so I changed out the spark plugs, cleaned the rats nest out of the intake manifold and drained the oil out of the lower. (No milky oil) Just wondering what is the correct weight gear oil and fluid capacity on the lower. Also, may be a dumb question but does the engine pull the same oil from the lower up into the engine itself or does the engine have a seperate camoflauge drain plug and fill plug? If so, what weight oil do I use and what is the capacity on it? Also, any other things that I should check out before cranking this bad boy up, other than the compression and fire? Thanks in advance for your help!
