removed prop to lube bearing,found lube fitting, hooked up to lube gun and it would not take grease. I removed fitting cleaned out hole and that was what it was,a hole. Is a dummy lube fitting or should there be a hole there to lube a bearing?My merc. maint. manual says it is for lubing a bearing,and so does yamaha. lube or not lube is the question.
