lubricating cables
summerslam
I saw a article that said when opening boat in spring that you should grease throttle cables. How is this done?
crab bait
Re: lubricating cables
just put alittle lube on the exposed ends & work back & forth...<br /><br />i personally ,, don't do it.. seems like grease turns into dirt...
SpinnerBait_Nut
I myself, always take my cables loose and spray a little 10W40 down them in the winter while I am winterizing and that seems to keep them free until spring when I will give them another shot of it and a little lube on my steering cables before I hook them back up.<br />Seems to work for me.<br />Throttle cables are not so bad, but them steering cables can be bear dogs if they get stuck.<br />Just my .02 worth.
