Lubricating my surge brake slide
BRICH1260
Got a Question. I have a 24` Rocket t24 trailer with surge disc brakes. Is the sliding mechanism inside of the tounge supposed to be lubricated. It appears to have white lithium grease at the edges, but I can`t find any fittting or place to squirt or inject the lube on the sliding mechanism. Any suggestions as to how this mechanism is to be lubricated.
gozierdt
Re: Lubricating my surge brake slide
I only use the "dry lube" type of grease on that kind of exposed
sliding surfaces. If you put a regular grease on there, it'll pick up
every bit of sand and grit that comes by. I'd just spray some of the
dry lube over the sliding surfaces.
