gonefishie
- Joined
- Jul 28, 2004
- 2,624
I was on my way to the license branch this afternoon and came up on a stop light. I slowed down, brake pedal felt normal at first then it got soft and I had to pushed it farther in to come to a complete stop. I was 4 blocks away from my destination. Light turned green, I kept going and had to push the pedal all the way down to stop in a parking spot. Put it in park, pumped the pedal and it never got stiff. Got out and saw brake fluid all over my front driver wheel. I then knew the line was broken. Went in to the license branch and had the best experience at a BMV ever. While inside I thought about limping home in low gear, bad idea. Got in the truck, brake pedal now has no resistance at all so I called a tow truck.
It turned out the brake line bracket came loose. The head of the bolt broke off. The weight of the bracket caused extra vibration and the break line broke right at the nut on the caliper side. I had a hell of a time getting those two nuts loose. The one on the caliper side wasn't as bad but the other one took all I had.
I inherited the majority of my tools from my dad and not one 10mm open end wrench. I ended up buying a whole set of metric open end wrench, a new channel lock and new vise grip pliers.
As I lay on the cold driveway, cussing at the seized up nuts. I realized that it could have been much worst if it happened on the highway instead.
Either my old man was watching over me or he just wanted me to buy new tools.
Thanks dad!
