M40c low RPM at WOT
I have this motor on a 1648 tracker mv hull. It's light as heck. I'm running a 14 pitch prop. Right now the motor sits too low, the cavitation plate is about 2 inches below the bottom of the boat. I have a jack plate on the way to fix this. Yesterday I took the boat out to see how it ran, best I could do was 25 mph at 3800 RPM, per a tiny tach. I had a decent load, 2 adults, 2 children, a dog, and an ice chest. Hole shot was pretty decent. Motor is healthy and running well. Will bringing the motor up raise my rpm's by almost 2000? Or am I going to be looking for a new prop too? I know I probably just need to get the plate on and experiment, but I thought I'd get some opinions here too.
pvanv
Yes, low jack height will cause that kind of symptom. Probably need less pitch as well.
Ok. As I'm playing with motor height and props, do I need to regulate RPM's or is there a rev limiter built into the cdi unit?
pvanv
A model that ancient may or may not have a limiter.
