featherfanatic
- Joined
- Jan 13, 2011
- 8
i just got a m40c running and have a question. there water out of pee hole is streaming strong and there is water out of idle check port.. check port water is warm and pee hole is cold.. i have it on muffs and after 3-4 minutes of running the head is too hot to even touch.. is this normal. if not any ideas where the problem may be? could it be due to having muffs on it and not in tank? not sure how much water i will lose in the muffs but it seems that the motor is getting to hot too quick..
Any ideas?
Thanks
Any ideas?
Thanks
