scout-j-m
- Joined
- Jul 31, 2009
- 642
I have Tohatsu M40D carbs on my 1988 Yamaha 30. Until recently they had the thick black fuel line connecting them together with the fuel pump. I threw it away and put on some 1/4" ID Tygon translucent yellow line. It is now leaking at the connection to the elbows on the two carbs without the fuel pump. The inlet/outlet of the fuel pump is not leaking, however, nor is the connection between the fuel filter and quick connect in the lower cowling. I found some 1/4" line like I removed and it goes on much more snug and probably wont leak. Just wondering if indeed 1/4" is the correct size? If so, maybe since the Tygon is more flexible with a thinner wall I should drop down to a 3/16" line. I really like to see the fuel flowing on multi carb motors so if there is an issue on the water I can verify that one carb isnt starving for fuel and running lean.
Also, the 90 degree elbow is a little loose where its threaded in the carb. Will any fuel resistant RTV from the auto parts store be ok to seal that up with?
