Re: M70A2 Overheat buzzer problems
Yes. If you refer to the wiring diagram, you will see that the rectifier converts the AC from the alternator to DC. The Tohatsu products today also regulate the output. No way for me to know about the RS unit. From the rectifier, you feed the battery system. I do hope your rectifier is robust enough for the job... and without a regulator, be careful that you don't boil the battery dry if you aren't using enough amps from the charging system...
