Just to keep it short, I replaced the adapter plate gasket last winter, only to have it fail near the end of my boating season this year. It was easier to take apart the second time, and now I'm in new territory again, dealing with a broken bolt where the leak occurred. Sorry, I have pics, but can't seem to upload them. The broken bolt was a 1/4"-20NC and 1" in length, right where the warm water from cooling the engine dumps into the lower leg. Keep in mind I've never done this type of work before. With the help of videos, I drilled out the broken piece and re-tapped the 13/64" hole to the original thread size. Unfortunately when I went to put it back together the threads were not strong enough to hold. Do I go the next size up to 5/16"-18NC? If I do, I can make the top part of the bolt fit in the adapter plate, but a socket will no longer fit. I was thinking I could grind a slot in it to use a screw driver to tighten? The 5/16"-18NC calls for a 17/64" hole, since I am having issues with strong threads should I drill to that size or re-tap with my original 13/64" hole? Any experience/advice is appreciated!
