Mark42
- Joined
- Oct 8, 2003
- 9,334
The power head from my 40hp twin is not really very large. I made a wood box 16" x 18" x 24" out of 3/8" flake board and 2x2. Made a cube from 2x2 and then screwed the flake board to it. Power head is wired to a 2x6 that is screwed to the base, which is reinforced with 1/2" plywood. The interior space is filled with rigid foam insulation (the pink suff I had left over from doing the basement). Cut and fit pieces of foam so the motor is wedged in tight top bottom & sides. Used a 2" hole saw and made hand hold holds in either end. I have not called UPS to pick it up yet. The crate feels solid, I have pushed it over and gave it some rough handleing. I don't hear the motor moving so I guess it is being held in place. <br /><br />My fear is that if it gets dropped it will break open. I would like to get it steel banded, but don't know where to go. Any ideas? Think it will arrive intact? Probably weighs around 50-60lbs.
