I got tired of sticking, retrieving, untangleing all my rods/reels in the corner of my small workshop/hide from the boss room. So I fabbed a gang rodholder out of 1.5" pvc and it works great. I got 10 1.5" pvc T fittings and had a 1.5" 90 already to put on one end. I cut 11- 2 1/8" pieces of pipe to connect the Ts and allow them to butt each other, good spacing center to center for freshwater spinning and baitcasters side by side. I then marked a 10' 1.5" pipe every 1' and drilled 3/4" holesaw holes in one side of the pipe every foot. I cut the pipe through the center of the holes w a mitersaw and that made notches in the ends of the cut pipes to hold the spining reels legs and the rods all neat and straight. I then assembled the whole thing w/o glue and layed a piece of 1x1.5" walnut I had laying around accross the 10 pipes and marked the centers of each T on the wood. I drilled a single hole through the long side of the wood at each mark so the holes are vertical when the brace is against the wall, behind the rodholders; and threaded a single strand of 3/8" rope through the first hole,around the pipe, down to the next hole around the pipe, through the hole repeat- all the way across the 10 pipes and pulled it tight to the upper ends of the pipes and knotted the ends to hold the pipes firmly to the brace instead of drilling and screwing them to it. Placed it on the floor, against the wall and marked and drilled @ the studs and screwed the brace to the studs. The 1x wood holds the rodholder angled slightly out at the top because the baseboard the Ts are against is 5/8". It looks neat and holds the rods great just have to be carefull w the 7' rods in and out so not to hit the ceiling w the tips when stuffing and removeing the rods. Cost was $17 for the T's I had the rest of the materials on hand. It could be built or expanded to hold more rods easily.
