guajiro0192
- Joined
- Feb 5, 2010
- 37
Hi all
I have a 1975 25hp evinrude ss. After finally getting a recurring fuel problem taken care of (ethanol) I thought all was going to be fine. I tried to start the motor, and got nothing, Had a sticking float. But in the meantime I took off the flywheel and tried to adjust the points and plugs. The motor would not start. Then once in a while would "lock up" as I pulled on the rope. It then once in a while would backfire. I thought that it was way too advanced, so I tried to adjust the points again. took the plugs out again and adjusted. I had a very week spark, then no spark! I bought a plug tester and still no spark.
The ?
How can I tell if the magneto is faulty? Do I need a meter? This motor is my nightmare? Trying to just get it to run and plane my 10ft zodiak. After that, I hope I throw a rod through the block and cowl. At that point it will act as an artificial reef! But at least it ran. }:-]
The ?
