Greg O.
- Joined
- Jan 9, 2011
- 125
I bought this 71 9.5 a couple of years ago on a boat. It didn't run very well so I set it aside. I could not get it to idle even after cleaning the carb. This winter I decided to make it run as it does have good compression. I decided to start with the mag and get it tuned up. The plate has some play in it so I took it off to see what I could do to tighten it up. Underneath the cam someone had put 8 snap rings to shim the cam high enough so it would engage the crankshaft key. The snap rings are riding on the seal, not good. What is missing here? Do I have the wrong cam and the tried to make another one work?
Another idea I had was to abandon the points all together and replace them with those electronic module that are made for small engines. I used one in a chain saw and it worked great.
