I got an oil leak, pooling small amounts in the valley of the Edlelbrock airgap rpm. The only places I can see that might do it are the intake bolts, if they penetrate the oil passages in the heads, or the distributor gasket. I snatched the dizzy , gasket looked dicey, so I made a better one, but I fumbled it going back in and rolled the shaft. Now i gotta try to orient the crnak with #1 at compression tdc, but I can't see the starboard side of the balancer. Even if I yank all the hoses, the circulating pump wraps around that half of it. I've tried a mirror and a light, what else is there? Do I really have to take the friggin' pump off? How does a guy tim one of these things?
