Re: Magic grinder wheel.
Does anyone have a preferred way to rapidly remove fiberglass.
I'm redoing my deck and changing the floorplan a little . I'm just using a 4" grinder with a standard wheel; is there anything better for this job?
turfman
hello, if u can get a helper, run a strong vacuum cleaner as u grind and sand aiming the discharge into vac's suction. works swell.
i once had central air installed in a house that had none. the installer came to me and said now we are ready to cut the ceiling for the vents. i am sorry, he said, but there is going to be quite a bit of dust.
oh no there is not, i said. i have it all figgrd out.
we will work as a team. u drill thru first. tap area to drill, i will put my 6hp vac up to ceiling to catch the dust from drilling. then i will know just where u will cut hole. then when u get ready to saw hole, i will have vac set to suck the dust...
he had never done it that way before.
anyway, to make a long story short... it worked perfectly! and the dust in house was minimal and no issue. i was determined not to loose to the dust...
and wear a mask & googles, too. a respirator is best.
regards
lakester
